Cisco gurus, tell me if this config is OK, terrible, will blow up my PIX 501, etc. It's a config hacked from peices of a PAT config that was working, some added port forwarding, and the default config. If anythings wrong tell me what and why and how to fix it, I'm trying to learn this stuff I don't have access to my PIX right now so I cant go ahead and test it unfortunatly.
EDIT: Updated config.
Code:
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname toaster
fixup protocol dns maximum-length 1024
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol http 8080-8081
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.100.101 workstation1
name 192.168.100.102 workstation2
name 168.168.100.113 netprinter1
object-group icmp-type friendly_icmp
icmp-object echo
icmp-object echo-reply
icmp-object source-quench
icmp-object unreachable
icmp-object time-exceeded
object-group network rfc1918
network-object 192.168.0.0 255.255.0.0
network-object 172.16.0.0 255.240.0.0
network-object 10.0.0.0 255.0.0.0
object-group protocol tcp_udp
protocol-object tcp
protocol-object udp
object-group network inside
network-object 192.168.100.0 255.255.255.0
object-group service http8080 tcp
port-object range 8080 8080
access-list outside permit icmp any any object-group friendly_icmp log
access-list inside permit ip object-group inside any
access-list inside deny ip object-group rfc1918 any log
access-list outside permit tcp any host workstation1 eq 400
access-list outside permit tcp any host workstation1 eq 1400
access-group outside in interface outside
access-group inside in interface inside
static (inside,outside) tcp interface 400 workstation1 400 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 1400 workstation1 1400 netmask 255.255.255.255 0 0
pager lines 24
logging on
logging standby
logging monitor notifications
logging buffered notifications
logging trap notifications
logging history notifications
logging queue 2048
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute retry 16
ip address inside 192.168.100.1 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm
pdm logging debugging 100
pdm location 10.0.0.0 255.0.0.0 inside
pdm location 172.16.0.0 255.240.0.0 inside
pdm location workstation1 255.255.255.255 inside
pdm location workstation2 255.255.255.255 inside
pdm location netprinter1 255.255.255.255 inside
pdm location 192.168.100.100 255.255.255.255 inside
pdm location 192.168.100.200 255.255.255.255 inside
pdm location 192.168.0.0 255.255.0.0 inside
pdm group inside inside
pdm group rfc1918 inside
pdm history enable
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.100.0 255.255.255.0 0 0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.100.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt security fragguard
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.100.120-192.168.100.129 inside
dhcpd domain ks.ok.cox.net
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
