Cisco Lab
taco24501
How far will this lab get me
3x 2620XM maxed out (SDM,CME)
1x 1760-v with fxs,fxo,VPN and PVDM12 modules
2x 2950T
1x 3350 with EMI and POE
4x WIC-1DSU-T1
1x WIC 1ENET
Still trying to find cheap phones,unity and terminal server
Should be plenty for CCNA/CCNA: V, and the CCNP: V (provided you add CUCM and possibly CUC to your lab). You'd probably want some more routers or Dynamips for the NP though.
Any ideas on routers? Im looking by the end of 2011 to to have ccna and ccna voice
What you have is plenty for the NA and NA: V (the one I took anyway, not sure about ICOMM). If ICOMM is similar to IIUC, you'll need to dig into some books/vids/screenshots on Unity Express, unless you want to spend a ton on an AIM-CUE or NM-CUE.
If you end up getting more routers, the XMs are good, you should consider the 26x1XMs though, like the 2611XM, 2621XM, etc. Those have two FE ports instead of just one.
