I am interested in setting up Netflow and in the process of building a CCNA lab. I am trying to figure out what the cheapest Router that supports Netfllow is? From my understanding the 2600 series support it? what about the analyzer software? is there a free or open source solution?
Also, Netflow is used for outgoing and incoming connections on the routers right? If you wanted to collect internal LAN information you would want to use SPAN or RSPAN on all the switches in your LAN correct?
I know Netflow is not on the CCNA but it interests me, the same with SPAN and RSPAN I plan to setup and play with on my switches.
