here is a show proc cpu during max load and normal load
MAX LOAD
NORMAL LOAD
The only problem is, I can't figure out what is causing the CPU to max out. The traffic isn't changing, and I can't identify what is causing the problem. I have however narrowed it down to PID 35 "IP Input", whatever that does.
I've disabled logging, debugging, etc.
MAX LOAD
router#
router#
router#show proc cpu
CPU utilization for five seconds: 99%/50%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 328563 639139 514 0.07% 0.01% 0.00% 0 Load Meter
3 941 268 3511 0.07% 0.00% 0.03% 0 Exec
4 12233 26630 459 0.00% 0.00% 0.00% 0 DHCPD Timer
5 4070062 401319 10141 0.30% 0.10% 0.06% 0 Check heaps
6 3968 984 4032 0.00% 0.00% 0.00% 0 Pool Manager
7 0 2 0 0.00% 0.00% 0.00% 0 Timers
8 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
9 4 2 2000 0.00% 0.00% 0.00% 0 AAA high-capacit
10 14859 106494 139 0.00% 0.00% 0.00% 0 Environmental mo
11 149971 121796 1231 0.00% 0.00% 0.00% 0 ARP Input
12 90972 159729 569 0.00% 0.00% 0.00% 0 HC Counter Timer
13 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
14 4 2 2000 0.00% 0.00% 0.00% 0 Entity MIB API
15 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
16 611194 3195145 191 0.00% 0.00% 0.00% 0 GraphIt
17 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
18 0 2 0 0.00% 0.00% 0.00% 0 SMART
19 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
20 502348 598836 838 0.00% 0.00% 0.00% 0 Net Background
21 8 95 84 0.00% 0.00% 0.00% 0 Logger
22 785459 3172604 247 0.00% 0.00% 0.00% 0 TTY Background
23 1314844 3195160 411 0.07% 0.01% 0.00% 0 Per-Second Jobs
24 0 2 0 0.00% 0.00% 0.00% 0 SM Monitor
25 0 1 0 0.00% 0.00% 0.00% 0 dev_device_inser
26 0 1 0 0.00% 0.00% 0.00% 0 dev_device_remov
27 0 1 0 0.00% 0.00% 0.00% 0 Net Input
28 292219 639142 457 0.00% 0.00% 0.00% 0 Compute load avg
29 2999423 53618 55940 0.00% 0.04% 0.00% 0 Per-minute Jobs
30 0 2 0 0.00% 0.00% 0.00% 0 AAA Server
31 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
32 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
33 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
34 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
35 61267103 10648252 5753 41.32% 46.47% 47.59% 0 IP Input
36 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
37 427564 407138 1050 0.00% 0.01% 0.00% 0 CDP Protocol
38 4 3 1333 0.00% 0.00% 0.00% 0 PPP Hooks
39 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
40 1963 15405 127 0.00% 0.00% 0.00% 0 TCP Timer
41 232 50 4640 0.00% 0.00% 0.00% 0 TCP Protocols
42 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
43 2832 10654 265 0.00% 0.00% 0.00% 0 HTTP CORE
44 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route
45 0 2 0 0.00% 0.00% 0.00% 0 PPP IPCP
46 497340 63931 7779 0.00% 0.00% 0.00% 0 IP Background
47 20663 53252 388 0.00% 0.00% 0.00% 0 IP RIB Update
48 125200 53254 2350 0.00% 0.00% 0.00% 0 Adj Manager
49 3614638 5249923 688 0.00% 0.00% 0.00% 0 CEF process
50 0 1 0 0.00% 0.00% 0.00% 0 Asy FS Helper
51 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
52 136 77 1766 0.00% 0.00% 0.00% 0 DHCPD Receive
53 650286 53230 12216 0.00% 0.05% 0.05% 0 IP Cache Ager
54 0 1 0 0.00% 0.00% 0.00% 0 COPS
55 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
56 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
57 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
58 2832071 3382783 837 1.36% 1.13% 1.18% 0 Inspect Timer
59 27736 110805 250 0.00% 0.00% 0.00% 0 CEF Scanner
60 0 2 0 0.00% 0.00% 0.00% 0 URL filter proc
61 2466 10653 231 0.00% 0.00% 0.00% 0 Authentication P
62 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B
63 0 1 0 0.00% 0.00% 0.00% 0 IDS Timer
64 31147 127831 243 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_
65 0 2 0 0.00% 0.00% 0.00% 0 LOCAL AAA
66 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
67 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
68 4 2 2000 0.00% 0.00% 0.00% 0 TPLUS
69 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
71 0 2 0 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
72 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
74 4177596 6345017 658 0.75% 0.73% 0.80% 0 IP NAT Ager
75 41607 904730 45 0.00% 0.00% 0.00% 0 DHCPD Database
router#
router#
NORMAL LOAD
router>show proc cpu
CPU utilization for five seconds: 50%/48%; one minute: 53%; five minutes: 79%
2 328707 639458 514 0.00% 0.00% 0.00% 0 Load Meter
3 212 58 3655 0.07% 0.03% 0.00% 0 Exec
4 12237 26643 459 0.00% 0.00% 0.00% 0 DHCPD Timer
5 4072710 401472 10144 0.00% 0.09% 0.06% 0 Check heaps
6 3972 986 4028 0.00% 0.00% 0.00% 0 Pool Manager
10 14867 106547 139 0.00% 0.00% 0.00% 0 Environmental mo
11 150047 121853 1231 0.00% 0.00% 0.00% 0 ARP Input
12 91004 159808 569 0.00% 0.00% 0.00% 0 HC Counter Timer
16 611445 3196736 191 0.00% 0.00% 0.00% 0 GraphIt
20 502666 599149 838 0.00% 0.00% 0.00% 0 Net Background
22 785779 3173887 247 0.00% 0.00% 0.00% 0 TTY Background
23 1315564 3196759 411 0.00% 0.00% 0.00% 0 Per-Second Jobs
28 292379 639461 457 0.00% 0.00% 0.00% 0 Compute load avg
29 3000891 53646 55938 0.00% 0.03% 0.00% 0 Per-minute Jobs
35 62637785 10652123 5880 0.95% 6.32% 29.38% 0 IP Input
37 427753 407336 1050 0.00% 0.00% 0.00% 0 CDP Protocol
43 2832 10659 265 0.00% 0.00% 0.00% 0 HTTP CORE
46 497620 63957 7780 0.00% 0.00% 0.00% 0 IP Background
47 20679 53278 388 0.00% 0.00% 0.00% 0 IP RIB Update
48 125256 53280 2350 0.00% 0.00% 0.00% 0 Adj Manager
49 3615071 5250410 688 0.00% 0.02% 0.00% 0 CEF process
53 653130 53255 12264 0.00% 0.05% 0.05% 0 IP Cache Ager
58 2857249 3386357 843 0.00% 0.03% 0.44% 0 Inspect Timer
59 27748 110853 250 0.00% 0.00% 0.00% 0 CEF Scanner
61 2470 10658 231 0.00% 0.00% 0.00% 0 Authentication P
64 31183 127894 243 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_
74 4195783 6349368 660 0.07% 0.04% 0.27% 0 IP NAT Ager
75 41627 905138 45 0.00% 0.00% 0.00% 0 DHCPD Database
router>
router>
