We just got a new house and it requires two wireless access points to cover the entire property for a usable internet experience. The ISP is Brighthouse networks (40mbps service). They have supplied an Ubee modem/router/phone unit. I went out and got a used Linksys E1500 300mbps N router to use as a wireless access point for the second floor/second half of the house. I have installed DD-WRT on it and set it up a wireless bridge repeater. It does receive signal and extend, but speeds are impacted pretty severely. Using the secondary network from the E1500, I get about 10mbps down using speakeasy's speedtest. Directly connected to the original Ubee SSID, I can get 20mbps, but the connection is spotty (hence why I got the E1500 to begin with). So, the question is -- is there a way to configure the E1500 to maintain the same level of speeds I can get using the original network, but keeping the new range and connection quality? Have the E1500 on the network also seems to slow it down as a whole.
maybe I should try using it solely as a bridge/access point as opposed to repeater...
