MrGuvernment
- Aug 3, 2004
Hey all,
I am on Shaw in Alberta Canada and they gave me the
Cisco DPC3848V DOCSIS 3.0 Gateway
http://www.cisco.com/web/consumer/support/DoC/c78-733353-00residential-wireless-gateway-model.pdf
By the spec's the thing is a beast, however, it's latency stinks on the LAN side...
Testing i did:
Asus N56U 192.168.1.1
Cisco 10.19.79.1
Using the same laptop and the same cable and just switching the cable between my Asus and the Cisco, you can see the difference:
Asus left pure <1ms, Cisco on the right with an avg of 5ms
I have disabled all "extras" that i can in the Cisco but the latency is the same. This stinks because someone opening web pages just takes seconds more just resolving.
I have tried changing DNS servers to various free ones (google, opendns and others) but no change as the issue seems to be latency to the router on the LAN side.
I just wanted to see if anyone else has one of these Modem / Routers and if they have similar latency to theirs...
Testing i did:
Cisco 10.19.79.1
