Cisco CUC and CUCM AA
Hey all,
Having a quick question regarding an AA setup on a Cisco Unity Connection system.
Right now I have the call handler setup, external calls are coming in and hearing the greeting. When the caller types in an extension number (which is in the list of subscribers in CUC), there is a long pause and then the call hangs up.
When I look at the reporting it shows that the call is being handed off to CUCM.
Now, if I call the AA extension from a phone registered in the CUCM and follow the same procedure, the call transfers fine.
I have also tried external calling setting up the gateway DID to the phone and it works fine, so I can verify external calls are working in CUCM.
Any ideas?
