Hi all,
I have a Cisco 2600 with a T1 WIC and an Ethernet port. The T1 is an Internet T1, but we only have ONE public I.P. (don't ask). Currently, the Cisco is doing NAT.
I need to be able to use that public I.P. on a Sonicwall.
Usually, I would assign an I.P. from the block to the Ethernet0/0 port on the Cisco and then another on the WAN port of the Sonicwall. In this case though, I only have 1 public I.P. and that gets assigned to the Serial0/0 interface of the Cisco.
I'm trying to bridge the Serial and Ethernet interfaces on the Cisco. So far I have:
- disabled ip routing
- created a bridge group (bridge group 1 protocol ieee)
- removed i.p. addresses from the serial and ethernet interfaces
- added the serial and ethernet interfaces to the bridge group
- disabled NAT
It doesn't work. I've searched and I can find plenty of instances in bridging a point to point T1, but not using a bridge to move the WAN I.P. to another device and basically using the Cisco as a T1 to Ethernet converter.
Any thoughts? This is killing me..
Thanks!!
Riley
- disabled NAT
Thanks!!
Riley
