Cisco ASA Sec Plus
What does show ver say? And I'm sure you've tried this but did you reboot it after entering the new license key?
Code:
Result of the command: "show ver"
Cisco Adaptive Security Appliance Software Version 8.4(1)
Device Manager Version 6.4(1)
Compiled on Mon 31-Jan-11 02:11 by builders
System image file is "disk0:/asa841-k8.bin"
Config file at boot was "startup-config"
DALFW01 up 38 mins 44 secs
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode        : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.06
                             Number of accelerators: 1
 0: Int: Internal-Data0/0    : address is c84c.7584.154a, irq 11
 1: Ext: Ethernet0/0         : address is c84c.7584.1542, irq 255
 2: Ext: Ethernet0/1         : address is c84c.7584.1543, irq 255
 3: Ext: Ethernet0/2         : address is c84c.7584.1544, irq 255
 4: Ext: Ethernet0/3         : address is c84c.7584.1545, irq 255
 5: Ext: Ethernet0/4         : address is c84c.7584.1546, irq 255
 6: Ext: Ethernet0/5         : address is c84c.7584.1547, irq 255
 7: Ext: Ethernet0/6         : address is c84c.7584.1548, irq 255
 8: Ext: Ethernet0/7         : address is c84c.7584.1549, irq 255
 9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces       : 8              perpetual
VLANs                             : 20             DMZ Unrestricted
Dual ISPs                         : Enabled        perpetual
VLAN Trunk Ports                  : 8              perpetual
Inside Hosts                      : 10             perpetual
Failover                          : Active/Standby perpetual
VPN-DES                           : Enabled        perpetual
VPN-3DES-AES                      : Enabled        perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 25             perpetual
Total VPN Peers                   : 25             perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
This platform has an ASA 5505 Security Plus license.
Serial Number: REMOVED
Running Permanent Activation Key: REMOVED
Configuration register is 0x1
Configuration has not been modified since last system restart.
Email from Cisco
Code:
licensing@cisco.com to me
show details 12:03 PM (49 minutes ago)
PLEASE DO NOT DISCARD THIS EMAIL.
You have received this email because your email address was provided to Cisco Systems during the registration process for a Cisco ASA 5500 Series Adaptive Security Appliance activation key.  Please read this email carefully and forward it with any attachments to the proper system administrator if you are not the correct person.
Below, you will find the Activation Key for your Cisco Adaptive Security Appliance.
Serial #:  REMOVED
Product Authorization Key   : REMOVED
Inside Hosts                   : 10
Failover                       : Enabled
Encryption-DES                 : Enabled
Encryption-3DES-AES            : Enabled
Security Contexts              : Default
GTP/GPRS                       : Disabled
AnyConnect Premium Peers       : Default
Other VPN Peers                : Default
UC Phone Proxy Sessions        : Default
Total UC Proxy Sessions        : Default
Platform = asa
REMOVED:   REMOVED
Installing Your Cisco Adaptive Security Appliance Activation Key
Step 1.  From the command line interface (CLI), enter configuration mode using the "conf t" command.
Step 2.  Type the "activation-key" command, and then, when prompted, enter the new activation key listed above.
Note:  For some new license settings to take effect a system reboot may be required.Software License Agreement
PLEASE READ THIS SOFTWARE LICENSE AGREEMENT CAREFULLY BEFORE DOWNLOADING, INSTALLING OR USING CISCO OR CISCO-SUPPLIED SOFTWARE.
BY DOWNLOADING OR INSTALLING THE SOFTWARE, OR USING THE EQUIPMENT THAT CONTAINS THIS SOFTWARE, YOU ARE BINDING THE BUSINESS ENTITY THAT YOU REPRESENT ("CUSTOMER") TO THIS AGREEMENT.  IF YOU DO NOT AGREE TO ALL OF THE TERMS OF THIS AGREEMENT, THEN (A) DO NOT DOWNLOAD, INSTALL OR USE THE SOFTWARE, AND (B) YOU MAY RETURN THE SOFTWARE FOR A FULL REFUND, OR, IF THE SOFTWARE IS SUPPLIED AS PART OF ANOTHER PRODUCT, YOU MAY RETURN THE ENTIRE PRODUCT FOR A FULL REFUND.  YOUR RIGHT TO RETURN AND REFUND EXPIRES 30 DAYS AFTER PURCHASE FROM CISCO OR AN AUTHORIZED CISCO RESELLER, AND APPLIES ONLY IF CUSTOMER IS THE ORIGINAL END USER PURCHASER.
The following terms of this Software License Agreement ("Agreement") govern Customer's access and use of the Software, except to the extent  (a) there is a separate signed agreement between Customer and Cisco governing Customer's use of the Software or (b) the Software includes a separate "click-accept" license agreement as part of the installation and/or download process. To the extent of a conflict between the provisions of the foregoing documents, the order of precedence shall be (1) the signed agreement, (2) the click-accept agreement, and (3) this Software License Agreement.
License.  Subject to the terms and conditions of this Agreement, Cisco Systems, Inc. or its subsidiary licensing the Software instead of Cisco Systems, Inc. ("Cisco"), grants to Customer a nonexclusive and nontransferable license to use for Customer's internal business purposes the Software and the Documentation  for which Customer has paid the required license fees. "Documentation" means written information (whether contained in user or technical manuals, training materials, specifications or otherwise) regarding the Software and made available by Cisco in any manner (including on CD-Rom, or on-line).
Customer's license to use the Software shall be limited to, and Customer shall not use the Software in excess of, a single hardware chassis or card or that number of agent(s), concurrent users, sessions, IP addresses, port(s), seat(s), server(s) or site(s), as set forth in the applicable Purchase Order which has been accepted by Cisco and for which Customer has paid to Cisco the required license fee.
Unless otherwise expressly provided in the Documentation, Customer shall use the Software solely as embedded in, for execution on, or (where the applicable documentation permits installation on non-Cisco equipment) for communication with Cisco equipment owned or leased by Customer.  NOTE:  For evaluation or beta copies for which Cisco does not charge a license fee, the above requirement to pay license fees does not apply.
General Limitations.  Except as otherwise expressly provided under this Agreement, Customer shall have no right, and Customer specifically agrees not to:
(i)     transfer, assign or sublicense its license rights to any other person or entity, or use the Software on unauthorized or secondhand Cisco equipment, and Customer acknowledges that any attempted transfer, assignment, sublicense or use shall be void;
(ii)    make error corrections to or otherwise modify or adapt the Software or create derivative works based upon the Software, or  permit third parties to do the same;
(iii)   decompile, decrypt, reverse engineer, disassemble or otherwise reduce the Software to human-readable form; or
(iv)    use or permit the Software to be used to perform services for third parties without the express written authorization of Cisco.
To the extent required by law, and at Customer's written request, Cisco shall provide Customer with the interface information needed to achieve interoperability between the Software and another independently created program, on payment of Cisco's applicable fee, if any.  Customer shall observe strict obligations of confidentiality with respect to such information.
Software, Upgrades and Additional Copies.  For purposes of this Agreement, "Software" shall include (and the terms and conditions of this Agreement shall apply to) computer programs, including firmware, as provided to Customer by Cisco or an authorized Cisco reseller, and any upgrades, updates, bug fixes or modified versions thereto (collectively, "Upgrades") or backup copies of the Software licensed or provided to Customer by Cisco or an authorized Cisco reseller.  NOTWITHSTANDING ANY OTHER PROVISION OF THIS AGREEMENT:  (1) CUSTOMER HAS NO LICENSE OR RIGHT TO USE ANY ADDITIONAL COPIES OR UPGRADES UNLESS CUSTOMER, AT THE TIME OF ACQUIRING SUCH COPY OR UPGRADE, ALREADY HOLDS A VALID LICENSE TO THE ORIGINAL SOFTWARE AND HAS PAID THE APPLICABLE FEE FOR THE UPGRADE; (2) USE OF UPGRADES IS LIMITED TO CISCO EQUIPMENT FOR WHICH CUSTOMER IS THE ORIGINAL END USER PURCHASER OR LESSEE OR WHO OTHERWISE HOLDS A VALID LICENSE TO USE THE SOFTWARE WHICH IS BEING UPGRADED; AND (3) THE MAKING AND USE OF ADDITIONAL COPIES IS LIMITED TO NECESSARY BACKUP PURPOSES ONLY.
Proprietary Notices.  Customer agrees to maintain and reproduce all copyright and other proprietary notices on all copies, in any form, of the Software in the same form and manner that such copyright and other proprietary notices are included on the Software.  Except as expressly authorized in this Agreement, Customer shall not make any copies or duplicates of any Software without the prior written permission of Cisco.
Protection of Information.  Customer agrees that aspects of the Software and associated Documentation, including the specific design and structure of individual programs, are trade secrets and/or copyrighted materials of Cisco, its suppliers or licensors.  Customer shall not disclose, provide, or otherwise make available such trade secrets or copyrighted material in any form to any third party without the prior written consent of Cisco. Customer shall implement reasonable security measures to protect such trade secrets and copyrighted materials.  Title to Software and Documentation shall remain solely with Cisco, its suppliers or licensors.
Term and Termination.  This Agreement and the license granted herein shall remain effective until terminated. Customer may terminate this Agreement and the license at any time by destroying all copies of Software including any Documentation.  Customer's rights under this Agreement will terminate immediately without notice from Cisco if Customer fails to comply with any provision of this Agreement.  Upon termination, Customer shall destroy all copies of Software and Documentation in its possession or control.
Customer Records.  Customer grants to Cisco and its independent accountants the right to examine Customer's books, records and accounts during Customer's normal business hours to verify compliance with this Agreement.  In the event such audit discloses non-compliance with this Agreement, Customer shall promptly pay to Cisco the appropriate license fees.
Export.  Software, including technical data, may be subject to U.S. export control laws, including the U.S. Export Administration Act and its associated regulations, and may be subject to export or import regulations in other countries. Customer agrees to comply strictly with all such regulations and acknowledges that it has the responsibility to obtain licenses to export, re-export, or import Software.
U.S. Government End User Purchasers.  The Software and Documentation qualify as "commercial items," as that term is defined at 48 C.F.R. 2.101, consisting of "commercial computer software" and "commercial computer software documentation" as such terms are used in 48 C.F.R. 12.212.  Consistent with 48 C.F.R.12.212 and 48 C.F.R. 227.7202-1 through 227.7202-4, Customer will provide to Government end user, or, if this Agreement is direct Government end user will acquire, the Software and software documentation with only those rights set forth herein that apply to non-governmental customers. Use of this Software and Documentation constitutes agreement by the Government entity that the computer software and Documentation is commercial, and constitutes acceptance of the rights and restrictions herein.
Limited Warranty
Cisco warrants that commencing from the date of shipment to Customer (but in case of resale by an authorized Cisco reseller, commencing not more than ninety (90) days after original shipment by Cisco), and continuing for a period of the longer of (a) ninety (90) days or (b) the software warranty period (if any) set forth in the warranty card accompanying the Product (if any): (a) the media on which the Software is furnished will be free of defects in materials and workmanship under normal use; and (b) the Software substantially conforms to its published specifications.   The date of shipment of a Product by Cisco is set forth on the packaging material in which the Product is shipped.   Except for the foregoing, the Software is provided AS IS. This limited warranty extends only to the Customer who is the original licensee. Customer's sole and exclusive remedy and the entire liability of Cisco and its suppliers and licensors under this limited warranty will be, at Cisco's option, repair, replacement, or refund of the Software if reported (or, upon request, returned) to Cisco or the party supplying the Software to Customer, if different than Cisco. In no event does Cisco warrant that the Software is error free or that Customer will be able to operate the Software without problems or interruptions.   In addition, due to the continual development of new techniques for intruding upon and attacking networks, Cisco does not warrant that the Software or any equipment, system or network on which the Software is used will be free of vulnerability to intrusion or attack.
Restrictions. This warranty does not apply if the Software, Product or any other equipment upon which the Software is authorized to be used (a) has been altered, except by Cisco, (b) has not been installed, operated, repaired, or maintained in accordance with instructions supplied by Cisco, (c) has been subjected to abnormal physical or electrical stress, misuse, negligence, or accident; or (d) is licensed, for beta, evaluation, testing or demonstration purposes for which Cisco does not charge a purchase price or license fee.
DISCLAIMER OF WARRANTY.  EXCEPT AS SPECIFIED IN THIS WARRANTY, ALL EXPRESS OR IMPLIED CONDITIONS, REPRESENTATIONS, AND WARRANTIES INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, NONINFRINGEMENT, SATISFACTORY QUALITY OR ARISING FROM A COURSE OF DEALING, LAW, USAGE, OR TRADE PRACTICE, ARE HEREBY EXCLUDED TO THE EXTENT ALLOWED BY APPLICABLE LAW AND ARE EXPRESSLY DISCLAIMED BY CISCO, ITS SUPPLIERS AND LICENSORS.  TO THE EXTENT AN IMPLIED WARRANTY CANNOT BE EXCLUDED, SUCH WARRANTY IS LIMITED IN DURATION TO THE WARRANTY PERIOD.  BECAUSE SOME STATES OR JURISDICTIONS DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, THE ABOVE LIMITATION MAY NOT APPLY. THIS WARRANTY GIVES CUSTOMER SPECIFIC LEGAL RIGHTS, AND CUSTOMER MAY ALSO HAVE OTHER RIGHTS WHICH VARY FROM JURISDICTION TO JURISDICTION.
This disclaimer and exclusion shall apply even if the express warranty set forth above fails of its essential purpose.
General Terms Applicable to the Limited Warranty Statement and Software License
Disclaimer of Liabilities. IN NO EVENT WILL CISCO OR ITS SUPPLIERS BE LIABLE FOR ANY LOST REVENUE, PROFIT, OR LOST OR DAMAGED DATA, OR FOR SPECIAL, INDIRECT, CONSEQUENTIAL, INCIDENTAL, OR PUNITIVE DAMAGES HOWEVER CAUSED AND REGARDLESS OF THE THEORY OF LIABILITY OR WHETHER ARISING OUT OF THE USE OF OR INABILITY TO USE SOFTWARE OR OTHERWISE AND EVEN IF CISCO OR ITS SUPPLIERS OR LICENSORS HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.  In no event shall Cisco's or its suppliers' or licensors' liability to Customer, whether in contract, tort (including negligence), or otherwise, exceed the price paid by Customer for the Software that gave rise to the claim or if the Software is part of another Product, the price paid for such other Product.  The foregoing limitations shall apply even if the above-stated warranty fails of its essential purpose.  BECAUSE SOME STATES OR JURISDICTIONS DO NOT ALLOW LIMITATION OR EXCLUSION OF CONSEQUENTIAL OR INCIDENTAL DAMAGES, THE ABOVE LIMITATION MAY NOT APPLY TO YOU.
The Warranty and the Software License shall be governed by and construed in accordance with the laws of the State of California, without reference to principles of conflict of laws.  The United Nations Convention on the International Sale of Goods shall not apply. If any portion hereof is found to be void or unenforceable, the remaining provisions of the Agreement shall remain in full force and effect. Except as expressly provided herein, this Agreement constitutes the entire agreement between the parties with respect to the license of the Software and supersedes any conflicting or additional terms contained in any purchase order or elsewhere all of which terms are excluded.
You need the 10 -> 50 or 10 -> UL license as well. And then you have to go through the hassle of contacting Cisco again and getting them to regenerate an activation key that has both the Sec Plus and the users.
Sec + gives you 25 IPSec VPN licenses and A/P Failover, you should have gotten the 50 user or UL bundle upgrade
What did you think the sec+ license was going to give you?
I figured it included more sessions
Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.Cisco ASA 5505 Security Plus license provides stateless Active/Standby high availability, dual ISP support, DMZ support, VLAN trunking support, and increased session and IPSec VPN peer capacities.
LOL i almost made the same mistake myself, then found out the sec+ didn't add more users. ended up getting the UL license. Thinking of selling mine on ebay and getting a higher model though that has gig ports
also sec+ gives MOAR VLANs, which I think is the most handy thing about it. being limited to 3 predefined VLANs is a major bumer on the lower end licenses.
well not specifically for gig ports i guess, was in a hurry yesterday, but as is i've already spent like 800 on my 5505 with jus the UL license, would rather just sell it on ebay for like 500 and take the loss and get a like 5510 with UL and sec+ license
What's the point though? You get better failover and beefier numbers in the 5510, but I don't see the need for it in a home setting. Why not just add Sec+ to the 5505 and have essentially everything you need? Not giving you shit, per se; just curious.
