Figured you Cisco guru's here can help me out. I bought a Cisco AP1231G-A-K9 wap off craigslist advertised as having a password and missing antennas for cheap, figured it'd be no problem. Using Cisco's own instructions on doing a password reset from here haven't worked. It has Cisco IOS, and supposedly holding the mode button for 1-2 seconds as it boots and the status light turns amber should let me login as user/pass Cisco/Cisco. It does not. I've noticed when it initially does the "press return to get started" it enters a username of 'wn' on its own and mentions a restart (bolded further down). Perhaps its setup not to be able to be reset? Seems to be a different startup that not holding the mode button, but still can't get into it. Help
Startup log:
Startup log:
Code:
[B]button pressed for 2 seconds[/B]
[B]process_config_recovery: set IP address and config to default 10.0.0.1[/B]
Loading "flash:/c1200-k9w8-mx.124-16b.JA/c1200-k9w8-mx.124-16b.JA"...###################################################################################################################################################################################################################################################################
File "flash:/c1200-k9w8-mx.124-16b.JA/c1200-k9w8-mx.124-16b.JA" uncompressed and installed, entry point: 0x3000
executing...
Cisco IOS Software, C1200 Software (C1200-K9W8-M), Version 12.4(16b)JA, RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 07-Jul-08 18:11 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x00505240
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 8 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 3229696
flashfs[1]: Bytes available: 4511744
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio 1 A506 5100 E8000000 A0000000 80000000 3
Radio 0 0 0 0 0 0 2
%Error opening flash:/c1200-rcvk9w8-mx/info (No such file or directory)cisco AIR-AP1231G-A-K9 (PowerPC405GP) processor (revision B0) with 15038K/1336K bytes of memory.
Processor board ID FTX0911E05L
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
LWAPP image version 5.1.151.0
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:13:7F:28:8B:22
Part Number : 73-8704-08
PCA Assembly Number : 800-23211-09
PCA Revision Number : A0
PCB Serial Number : FOC09081C7W
Top Assembly Part Number : 800-23304-08
Top Assembly Serial Number : FTX0911E05L
Top Revision Number : A0
Product/Model Number : AIR-AP1231G-A-K9
The name for the keys will be: ncmc-3se-ap03.cisco.com
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
Press RETURN to get started!
*Mar 1 00:00:04.116: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:05.376: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar 1 00:00:05.454: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 282 messages)
*Mar 1 00:00:07.606: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to do
[B]User Access Verification
Username: wn
*Mar 1 00:00:10.828: %SYS-5-RESTART: System restarted --[/B]
*Mar 1 00:00:10.886: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:10.951: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:00:11.304: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning frequencies for 11 seconds
*Mar 1 00:00:11.957: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:22.158: %DOT11-6-FREQ_USED: Interface Dot11Radio0, frequency 2432 selected
*Mar 1 00:00:22.159: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:23.159: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:00:26.908: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:26.912: bsnInitRcbSlot: slot 1 has NO radio
*Mar 1 00:00:26.938: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Mar 1 00:00:26.946: SSC Load Current Size crypto_mykey 120, offset 9385, Saved Size soap_cert_crypto_mykey 124
*Mar 1 00:00:27.643: Logging LWAPP message to 255.255.255.255.
%LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
%SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
% Username: timeout expired!
ncmc-3se-ap03 con0 is now available
Press RETURN to get started.
Username: Cisco
Password:
% Authentication failed
