Hi Guys, could someone help me out? I have a problem with clients behind the 887W not being able to get out on the internet. When the Dlink is plugged in, everything is ok so the problem is in the config. Any ideas?
887W or DLINK 192.168.77.1 255.255.255.0
SERVER 2008 (DHCP, DNS); IP: 192.168.77.6 255.255.255.0
CLIENTS; get IP from server above and default gateway is 192.168.77.1 255.255.255.0
877W#ping 4.2.2.2
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/26/28 ms
877W#
Code:
877W#sh run
Building configuration...
Current configuration : 2564 bytes
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname 877W
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
dot11 ssid CM
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 0 cisco123
dot11 ssid Computer
vlan 1
authentication open
guest-mode
no ip subnet-zero
ip cef
multilink bundle-name authenticated
vpdn enable
no crypto isakmp enable
archive
log config
hidekeys
bridge irb
interface ATM0
description ADSL
no ip address
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
bundle-enable
bundle enable
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
pvc 1/1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid Computer
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
ip address 192.168.77.1 255.255.255.0
ip nat inside
ip virtual-reassembly
bridge-group 1
interface Dialer1
description PPPOE
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username USERNAME password 0 PASSWORD
ppp ipcp dns request
interface BVI1
ip address 10.0.1.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 1 permit 192.168.77.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input telnet ssh
scheduler max-task-time 5000
end
877W#
