I've been asked by my work to get a VPN up and working. When I first came here we had a Linksys BEFVP41 router. I tried and tried to get it to connect to VPN's, and although I could get the router to connect to a Linksys Support Tech's VPN, I could never get another computer to connect to it. 3 more support calls later, a different tech casually suggests that perhaps the reason I can't connect this routers VPN with a computer is because the series of router that I am using only supports Router-Router VPN connections. Gee, thanks for specifying this Linksys.
So I run down to CompUSA and buy another Linksys router, the WRV Series, which I KNEW supports Cline-Router CPN connections (The Linksys tech assured me that it did) Funny thing is, when I got the goddamn thing back to my work to try and get the network set up, there is a known firmware bug where the router is unable to access the Internet via the wired ethernet ports. I got on the phone with their crappy tech support again, where they suggested I do a reflash, and then upgrade the firmware. Not suprisingly, this didn't work, and I had to return that router as well. Now I'm back at square one.
I've decided to bite the bullet and invest in a decent Cisco router this time, not a cheap over the shelf peice of shit. I've been eyeing the Cisco 800 series of routers, and I think the 871 will suite myself and this buisness quite well. However, I do have some questions.
Does the 871 series of router use a web based interface to configure its settings, as opposed to cisco's terminal interface? I have never used a Cisco product before, and I don't know the first thing about using their non-web interface.
Does this router support a remote VPN client. As in, can I connect to these routers VPN via a remote client set up on a laptop in a hotel room?
Does anybody have experience using this series of router?
Are there any other VPN routers I should try before I go and buy this Cisco Router?
