Hi,
I am running a Cisco 3548 48 port switch with IOS Version 12.0(5)WC17XL (latest)
I have decided to put in a 1000Mb Base-T backbone in for my home servers and connect them to the Switch via a WS-G5483 module.
The problem I have got is that the switch does not see the module (I have 2 and tried both in both ports on the switch)
This is what I get from the switch
Code:
GigabitEthernet0/1 is down, [b]line protocol is down[/b]
Hardware is Gigabit Ethernet, address is 0003.e3e7.23b1 (bia 0003.e3e7.23b1)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive not set
Full-duplex, 1000Mb/s, [b]media type is missing[/b]
output flow-control is off, input flow-control is off
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output 01:05:21, output hang never
Last clearing of "show interface" counters never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
7 packets input, 448 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
7 packets output, 448 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
