I've found myself with a not so obvious choice of whether to get a 2651XM or a 3640. I plan on buying a 4 or 8 port serial module along with several more serial wics to setup frame relay which will work in either model. I plan on adding one of these to a lab which I hope to be able to make use of when I tackle the CCNP after I complete the CCNA.
I currently have (6) 2611, (1) 2950T, (1) Catalyst 4003 (pretty much useless), and (3) 2924C-XL's.
One major difference is that the latest version (2) of the SDM is not supported on the 3640, but is supported on the 2651XM. I believe that both of these machines can use the 12.4 IOS. I'd rather use the CLI than the SDM, but the CCNA is looking for experience with the SDM. I'm not sure if the CCNP will bother with the SDM.
Any recommendations?
tia
tia
