Hello, I have a rather large Cisco Lab and 3 of the routers I have are Cisco 2650s. Well they are only able to take the IOS version 12.4M and 12.4T is only compatible with the XM series.
So I was thinking what would happen if I threw the 12.4T on the device, well I was surprised but it boots and functions with that image. So here is the question, is this usable in a LAB environment (CCNA/CCNP studies ect) the thing that would worries me is the memory. It is recommended the 12.4T IOS has (I think) 196D/48F. Well the 2650 non-xm only supports 128D/32F. The IOS fits on the 32 Flash (with 300k to spare) though what issues can/will i see in the future?
If its ok to have 12.4T on this it would save me on upgrading them in the future (^.^)
Code:
Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(9)T2, RELEASE SOFTWARE (fc4)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 18-Nov-06 14:32 by prod_rel_team
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 2 days, 2 hours, 53 minutes
System returned to ROM by reload
System image file is "flash:c2600-adventerprisek9-mz.124-9.T2.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
[email protected].
Cisco 2650 (MPC860P) processor (revision 2.0) with 127524K/3548K bytes of memory.
Processor board ID JAB05310D2F
M860 processor: part number 5, mask 2
1 FastEthernet interface
4 Low-speed serial(sync/async) interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
