DigitalPimp
Fred Garvin - Male Prostitue
- Jul 7, 2000
I have a 2600 routing between to networks and the routing and broadcasting works fine. Except the router seems to stop routing packets after about 5 minutes of continuous pings from one network to the other. Communication to the devices stops. Communication from on the same network still works, so the router is stopping packets or something. Is there some sorta "keep alive" command I need to impliment or something to that effect? Any info helps.
Thanks
Thanks
