Cisco 2500 & Trancievers
cburwell
I have a few Cisco 2513 routers, which have AUI ethernet ports. I have CentreCOM Ethernet transceivers to convert the AUI port to a RJ-45 port.
The problem is that when I power the router on and connect a computer to the transceiver, I do not get any link on either end. Is there something else that I need to do to get the transceiver to work with the router?
Thanks for the help!
i assume you set an ip address, did a no shutdown and everything else needed to bring up the interface?
other than that what kind of cable are you using crossover or straight through
The only thing I can see is that the config for that interface says "Line protocol is down". I know this refers to the data link layer, but I can't figure out how to bring it up.
I am using a regular cable (straight).
ethernet to ethernet (router) should be crossover...! but youll need a rollover to the console if you haven't config'd it yet
cburwell said:
The only thing I can see is that the config for that interface says "Line protocol is down". I know this refers to the data link layer, but I can't figure out how to bring it up..
What have you done to configure the interface?
I just waled through some stuff in the book I have:
(in config interface mode)
ip address 192.168.1.1 255.255.255.0
no shutdown
end
I have a console cable already.
I think the problem is my cable. So even with router (transceiver) to my laptop I should have a X-over cable?
Routers and computers are considered "like devices" so a x-over cable should solve your link problem.
That’s absolutely correct. That’s your problem.
You need a cross-over cat-5/5e cable to connect a DTE to DTE. Both routers and PCs are considered DTE devices.
You can buy one or make one yourself. Just connect (pins 1 to pin 3) and (pin 2 to pin 6).
