let me be more clear, it's a setting on the AP itself, has nothing to do with the switch. I had some 1131ag access points that drew more power than the 3524XL is capable of delivering per port which is documented on their site. Then we used a bunch of old power injectors that the client had laying around instead. Had to set the the power option on the AP to, I think, pre-standard negotiation or something and then they fired right up.
did you check the power settings on the AP? set to pre-standard from the sys config page and that should work for you.
Got another Power injector still not working. I dont know if this helps but if i plug directly into the 1130 access point and let it sit everything lights up green but as soon as i plug it into the Cisco 2948G it turns orange.
Just to be clear, your 2948G is not a PoE Switch correct?
The 1131 AP will power up & work normally if only connected via an ethernet cable to the injector on the 'AP' port?
When you plug a ethernet cable from the 'network' side of the injector into your 2948 switch, the 'status ring' goes orange?
You are only providing one source of power via PoE?
Any way you can pull the event log and show us what the error is when it goes from green to orange?
