[CiP] MCE MbK
kier
Hi my modding friends,
I'm working almost 2 weeks now on a nice little project
And would like to share this with you. A kind of MCE / NAS for in the living room
(actually the only place without a PC) My wife was always against this, so I had to promise that it has to be a winner
And (almost) without sponsorship :)
This year's Cebit, I bought a kind of prototype NAS thing , made of some Acrylic and aluminum.
Real ugly, but this is gonna change....I hope ;)
I have a few last remaining pieces of UV green acrylic so this I'm gonna use for this build, with black ;)
Hardware:
2x HDD, Western Digital Greenpower 1.5TB
1x Intel 160 GB SSD
Een Asus E45M1-1 Deluxe
Een 220 Watt Coolermaster PSU
4x 60mm Coolermaster fans
The "thing" disassembled
And everything pulled apart
The Asus mobo
Enough Sata's and a PCI-e
DDR3
It fits :)
Already cut 2 green pieces of acrylic
Bottom
And placed the 2 HDD's
Fits next to the motherboard
For both sides I have cut a piece of UV green acrylic
Cut the shapes for the air-outlet
Same form as the original, still need to cut the fanholes for the 60mm fans
Also cut a piece acrylic for the front. And another piece slightly curved with 60mm fanholes.
I changed the fanholes and made square holes ​​with the dimensions of the fans
And sawn an aluminum plate with fanholes, this will be black acrylic which is looking better, I think
In the upper layers of black and green acrylic (in the middle) I cut a rectangle with the dimensions of an SSD
The cut rectangular green acrylic on the SSD.
Made the aluminum bars black.
And a little teaser for the next update ;)
Ok you guys, this is becoming a high speed build;) The small tubes/ spacers that I showed in previous update is to create distances between the green and black acrylic
Step by step
Green acrylic on top
placed the bars
Placed the original sides with 60mm fans mounted
Cut a horizontal plate and placed it
Against this comes the bent piece of acrylic with the 60mm fans
Here I slide the existing piece and clamp the curved piece
Also cut the fanholes in the side plates
Placed the spacers also to the side panels. (bolts are going to be replaced ;) )
Both sides
And on top placed spacers again with a piece of black acrylic
Most acrylic is finished, Next job placing the hardware ;)
One of these days, you're going to do a mod that I absolutely hate. But not today!
That's really neat! I quite like it. Looks much better than it did before :D
Lol...thanks
;) Thank you
Update !!!
Coolermaster has given me a nice little PSU. The flex ATX 220w
Sad but true ... has to open for the sleeve job
First series of cables sleeved black.
Molex etc. also black
Used my Lamptron for the first time and must say it is a very useful kit.
Made the 24pins green.
And some black (had no more green)
To fit everything I have placed the mobo, HDDs and rams.
Placed the HDDs with some spacers
Now I can anticipate the little space I have left, so i've made ​​an aluminum tray for the PSU
Made it black
And attached it to the green acrylic.
Also made the rear from a piece of aluminium and cut the recesses for the IO shield and the PSU
Made the IO shield black
Fortunaly I had still some black Dominators
And now the challenge to get everything in the case ... but will certainly succeed ;)
Little change of plans but I've got the solution!!!
My wife wanted something for her Iphone, smartphone, Ipad, Tablet, MCE and NAS
Hopefully this will keep her quiet :D
Looks like an Asus Transformer tf101 which is the same model I have, and the dock connector is on one of the longer ends because it docks horizontally with a keyboard.
You should do that with an HP Touchpad. Why an HP Touchpad? Because the charging dock doesnt plug in a cable, its inductive charging. Some people report it is transfering information over the charger as well, but I dont know about that. But the charging part is cool.
Not docked in mate, just for supporting her stuff ;)
Hmm, forgotten to update this one...sorry ;)
Final Update!!!
Where were we. The SSD I think
I have a nice 60GB SSD, this is more than enough for her.
Some extra storage
On the pictures you can also see that I have removed the sleeve... With it there was no room left.
Made some LEDs and a switch in ​​it
Power on
Made a cover for the front
Must find some nicer bolts lol
The cover for supporting her.....
And installed W8, time for her to find out how it works and where everything is;)
That's it!!!
