Yea works with the all episodes too. My only criticism was they didn't make the girl look slutty enough, even with the other outfits.
Not only does it work with all episodes but I believe you actually need all episodes to get it to work as you need the engine updates from episode 2.
yeah i think you're right. if i recall correctly from back when i installed CM 9, the author instructs you to launch each of the episodes at least once before installing.
i don't mind him changing alyx to look like adriana lima, but just give her a somewhat normal appearance and normal clothes. leave the g-string whale-tail and cornrows out.
I'd much rather have a mod that gives you ironsights and locational damage (besides headshots) and more enemies.
I just took a look and, for me, I liked the one from #2, #3 looked like a bad nose job, then it just got worse and worse... #10 looks like someone rolled over her face or something... maybe that was a different character, but seriously WTF is up with the black eyes and plastic, stick-up-the-butt expression?I remember in one of the older CM releases (like 6 or so) he had an option for an HD but otherwise stock Alyx.
And I agree with the previous posts saying leave Alyx alone. They spend so much time working her over she looks like a truck on the way to a whore convention smashed into a plastic surgery clinic.
If you've played with one of the CM mods before (I have no idea what #, it was years ago, I believe the first), is #10 worth doing it again?
I would say no, IIRC i think after CM7 Fakefactory started adding and removing assets in the game. Along with his obession to change the appearance of Alyx, Barney and the rest of the civillians. I think CM7 was the best version Fakefactory made.The majority of the models were just HD versions of the original. Although, I'm not too sure if it works with the current version of HL2, EP1, & EP2
