Chrome sudden white screen
Whach
Since release 32, Chrome has gone down the shitter for me. Frequent tabs always result in white screen until the browser is resized. Have tried reinstalling everything, chrome, flash and drivers. Methinks im using good ol firefox until Google sorts it out. Anyone else have the same problem?
Yep, I'm seeing the same problem as well. This also messes up Hangouts until you resize it, too.
Edit: Better start posting basic specs:
Windows 8.1, Nvidia GTX 670s in SLI.
Edit 2: Turns out that SLI might very well have something to do with it. Check out the bottom posts: https://code.google.com/p/chromium/issues/detail?id=325309
Edit 3: Okay, here's a decent workaround: https://productforums.google.com/d/msg/chrome/vyqnrgA3aKc/d5fvdOTRbNEJ.
Edit 4: Well, my configuration already had that function disabled, so I'm just going to turn off hardware acceleration for Chrome and try it out again later when Nvidia releases a new driver.
Everything was working fine for me I until the new chrome update. I've just reverted back to chrome 31 and it's running well with no incidents. No way I'm disabling hardware or drivers to accommodate Google's chrome 32 turd! I'll give it a go in the next driver update just to be sure though. If not, back to chrome 31 again.
