Chosing optimal radiator orientation
Schleepp
Which is the most hassle ... bleeding or draining?
Got 2 x 480s and they are going in my build vertically. I'm having a hard time determining if ports go up or down ... if down, draining them will most likely be easier while I assume bleeding will take a bit more effort and vice versa.
I'm just guessing as I'm totally inexperienced and this is my 1st loop.:confused:
From my experience bleeding is harder, but it could go either way if you don't have a easy to get to low port for draining. If you got a powerful enough pump it is usually enough to push the air out into the res to bleed.
Without seeing your setup I cant tell you much more, just remember while building that you want an easy way to get the water in and out.
