Choppy Playback with 720p
the_body90
I get choppy playback on my new PC.
I use VLC and the current file is a .mkv. I can play on all my other systems. The difference is dual core. I think i should be able to play 720 from the Hard Drive with the specs below.
Hardware accelation is at full
Latest Nvidia Drivers
Directx 9c
Specs:
AMD 64 3000
2 GB DDR
200GB HD
7600GT
XP Pro
Asus P5N
Using VLC
Ideas?
I read over thread. After following all the directions, I can play HD videos.
Problem with VLC is that it uses CPU for HD encoding. Using all the links posted I now use WMP for HD playback.
Reminder, installing only some of the encoding packs may result in sound or lagging problems. I installed all and it worked first try.
Thanks.
