I have a Buffalo Wireless to Ethernet bridge installed, and I went out and bought a linksys SMA antenna thinking it would fit nicely in the place of the Buffalo antenna. I try to screw the antenna in, but there is plastic on the sides of the connectors stopping it from going in because the antenna diameter is too big.
Instead of just taking the thing back, I decided to take out my trusty old swiss army knife and cut around the plastic to make it fit. I now have a ghetto WtoE bridge which gets a slighly stronger signal strength.
Just a warning to those who buy the linksys high gain antenna thinking it will fit their off-brand product.
