DarkTyrian
- Jan 26, 2005
Hi guys,
I'm building my first comp and I need a little help and guidance on choosing the correct pieces. I think I've gone a good job so far, but am a little confused about the cpu cooler. Is it suppose to be compatible with the cpu or the mobo? Below I will post my proposed setup, if you could give me some suggestions on cpu coolers that will surely fit that would be very helpful.
Thermaltake VA3000 Dream Tower http://www.newegg.com/app/viewProductDesc.asp?description=11-133-132&depa=0
AMD Socket 939 Athlon 64 3500+, 90nm, 2.2 GHz, 512KB L2 Cache 64-bit Processor - OEM (Winchester Core) http://www.newegg.com/app/viewProductDesc.asp?description=19-103-494&depa=0
CHAINTECH NVIDIA nForce4 Ultra Chipset Motherboard For AMD Socket 939 CPU http://www.newegg.com/app/viewProductDesc.asp?description=13-152-049&depa=1
MSI nVIDIA GeForce 6600GT http://www.newegg.com/app/ViewProductDesc.asp?description=14-127-147&depa=0
PDP SYSTEMS Memory Dual Channel Kit 184-Pin 1GB (512MBx2) DDR PC-3200 http://www.newegg.com/app/viewProductDesc.asp?description=20-220-006&depa=0
So based on that setup what are my options in the line of cpu coolers. I'm not looking for water cooling since it's a little expensive so if you could keep it to regular heatsinks and fans that would be great. Please do not post about coolers that will require me to modify my mobo, cpu, or case. If you know of a cooler that will fit than please let me know. Very Happy
Thanks for your help
