Choosing fans
Psycrow
Hi
I have a coolermaster master case pro
and i bought these fans to the front
http://assets.hardwarezone.com/img/2016/09/nzxt-aer-rgb-hue.png
Then i need 2 fans for the top, but they must be 140mm and the air flow must blow out of the case
and be able to show me lights, so i can see the fans lights from above my pc.
The reason why they must light up and shine out of the case rather than inaise is becauce i have this HUGE noctua cpu cooler that takes alot of space and might block some lights..so what would be good fo rme to choose ?
Also they must be low noise
I have seen these but they are only 120 mm and i would like to have 140
https://www.computersalg.dk/i/1946245/corsair-air-series-led-hd120-rgb?sq=corsair+hd
You dead set on lighted 140mm fans? That will be limiting factor.
For silence I would recommend Noctua NF-A14 ULN. Or the FLX models if you want more flow. Then you could go with
some Lazer LED clusters underneath for lighting.
I have these in mine. Couldn't see using anything else & I don't need flashy LED's.
