Choosing Best case suggestions?
PANOS
Because this time I was in search of a big case for the reasons that I need it because I want it to reconstitute the new system I am preparing for this time, my main goal in that case to have , the very big places and spaces as well as a custom watercooling that will be used later on for the whole system, besides that I want the case to be overflow and can be moded. I have seen 3 cases but I do not know their advantages and disadvantages. the choice will be made in these cases
can you tell me please their advantages and disadvantages and which case can be considered the most ideal?
OBSIDIAN 1000D SUPER TOWER -
ENTHOO ELITE SUPER TOWER CASE – BLACK -
COSMOS C700M RGB FULL TOWER CASE – BLACK TEMPERED GLASS
https://www.amazon.com/CORSAIR-OBSIDIAN-Super-Tower-Tempered-Aluminum/dp/B07BQG4TM3
https://www.amazon.com/Phanteks-Enthoo-Extreme-Chassis-Aluminum/dp/B01N9OKX5U
https://www.amazon.com/Cooler-Maste...&ie=UTF8&qid=1546548327&sr=1-1&keywords=c700m
in one from these 3 cases will be added
2 psu
4 hard disks
2 ssds
2 graphics cards. (1080Ti * 2)
2 dual cpu (cpu + motherboard) (2 motherboards and 2 processors)
In addition, the 2 cpus we have at this time were AMD Ryzen 5 2400G Processor, AMD RYZEN 2700
and a custom watercooling in the future
power supplies we will use Corsair AX1600i and Corsair SF600 600W
which from these 3 cases is the best in everything this i mean;;
i want one very good case to have plenty of space for ssds and hdisks parts,, gpus and custom cooling and also to have very good airflow.. and also to have very good temper glass and also to have space for to put a lot of fans
I want to have very good Great cable management ,,to have
Support for several liquid cooling options and also I want to Support just about any crazy build..( E-ATX and Mini-ITX build at the same time)
which are the best ultra towers for to look for;;
I need one ultra tower because I will put a lot of things inside,and I want to be comfortable in every part which I will put inside in the ultra tower. for every crazy build
why my friend;
these 2 cases
ENTHOO ELITE SUPER TOWER CASE – BLACK - are not good for dual cpus;; and custom watercooling options;; and for large spaces;;
