Hi guys, I've decided to deck out my Stacker 830 with 120mm fans connected to a 7 channel fan controller. I've been googling for ages now but specific information on something as mundane as fans seems to be hard to come across.
I have some requirements that I need to meet, so I was wondering if fellow [H]'ers have any fans that match what I'm looking for. Basically the requirements are as follows:
- 120mm x 120mm x 25mm (a fair few seem to be 38mm thick)
- Have a RPM sensor lead. It can be in the form of a 3pin (ideal) or a 4pin molex with a seperate RPM cable (which I will use a 4pin > 3pin adaptor)
- Have a high CFM. No particular preference, but I would like around 70 CFM or higher.
How loud or quiet they are is not an issue. The focus is shifting as much air as possible when I need to, but for the most part I expect them to be off or used on a low setting. I also don't care if they are plain black fans, or every colour of the rainbow, but black would do fine
I had my eye on the Thermaltake A1280, but from the limited images I found, I wasn't able to tell if it had an RPM sensor or not.
Many thanks
Many thanks
