Choose between mobos...
sbrown23
Getting ready to build a new PC, my first A64-based, though I've built many AXP and Duron-based machines. Will be getting a Winchester 90nm A64 3200+, 1GB PC3200 RAM (probably Corsair or Crucial), and probably new video card to replace my Radeon 9700. Not sure about the Socket 939 motherboard to get though. Looking at the MSI K8T Neo2-FIR ($116 Newegg) or the Asus A8V Deluxe ($137 Newegg). I may lightly overclock the board to eke out some extra performance, but will not stretch to the limits as stability is my overriding concern.
Will be doing the following: photo editing, video editing, some gaming (not heavy)
Seems like the A8V has some nicer features but is it worth the extra $$$? Also, is it worth it to wait for the Nforce4-based motherboards coming up soon, or should I just go with an Nforce3 or K8T800 board?
Side note... I was a long time member here before (since '99 or so?), and my account was deleted! Hadn't been around for 6-8 months, and come back and had to create a new account with my same name. Was there a major crash on the boards or something??
i would say get the Asus..but if you ever got problems with the board..your screwd cause Asus has the worst support....i have had bad performing MSI boards all the time...and if the Asus is 20 bucks more...hell go for it...asus boards are really nice if you get a working one...not this this one isnt going to work. It probrably will.....
my 2 cents
