Choices Choices
... Uhm...
REALLY hard choice. I don't like either.
I'd say first... and give it a "Hey look what I found at the bottom of the lake" theme.
i have a $100 gift certificate :D
Arcygenical said:
... Uhm...
lol, that actually gives me an idea.
khanable said:
what is your gift certificate amount?
out of those three I'd probably try the chakra..
but I guess it depends on the mods you'll be doing..
http://www.xoxide.com/temjin1s.html
is pretty sweet for a few bucks more
60mm fans up front, a single 80mm fan in the rear, and a warning saying Power Supplies more than 6" long or Modular PSUs wont work, when was this case designed, in the 80s? I would stay well away from it!
I was thinking earlier today. If i were to do a black/green black/red project what would you reccomend from xoxide if you can think of anything offhand? Id like to keep under $100 dollars is the thing, I honestly considered the thermaltake swing for $53. Its not a bad design.
