Choice between 2 22" CRT's Need Help...?
NEC / Mitsubishi all the way. I would recommend you to get NEC 2141sb, or Mitsubishi 2070sb cause they are one step even better(the best) CRT they have(both use same hardware). Or in the other hand, HP's P1230 is too using same hardware(i have it).
Anyways, That NEC u were wondering is good monitor too, but i would recommend to get the 2141. It has even better refreshrates and resolution support and overall more bandwith = cleaner picture.
Check this too:
http://www.hardforum.com/showthread.php?t=917180
I've got the FE2111SB in white....think it is actually a bit cheaper than the black if Newegg still carries it. Great monitor. Once you go with a NEC CRT you'll never go back to an LCD. :p :p :p
