CHKDSK on a SSD?
Synomenon
Usually when I run error checking / check-disk, I don't run it in Windows. I'll open the command prompt and type:
chkdsk c:/f/r
It will say something to the effect of, "The drive is currently in use. Schedule this drive to be checked next time the system restarts?".
Is it safe to do this on a Vertex? Is it even necessary to do this on a SSD?
Far as I know it makes no difference if it's an SSD or HDD, since it's mostly the filesystem chkdsk checks/fixes.
