{NcsO}ReichstaG
- Aug 13, 2004
Hey,
so i finally got my new setup (in my sig to work) and under heavy load, the chipset temp. rises to between 45-52C. Is this too high?
If so, what do you suggest I do?
1) Remove cooler, apply AS5 and hope it helps (maybe place an 80mm fan as close as I can to it)
2) Buy another cooler? IceBerq?
-Thanks
-Thanks
