Robbie Hanson
- Oct 30, 2006
Hey guys,
I'm currently running this:
Gigabyte 880GA-UD3H
Phenom II X6 1055T @ 3.2 (stock voltage)
2x Gigabyte HD6850
Antec HCG-750 750w
Antec 300 case
I'm experiencing heat within the case to the point that it's physically hot, not warm, to the touch. All internal components, including the heatsink, feel cool--EXCEPT the northbridge heatsink, which is hotter than blazes and which I can barely touch. Temperature seems fine in Coretemp, Speccy, and Speedfan; 48C, 46C on hard drives, 55/51C on GPUs, 39C on CPU. Is it normal for a chipset to run this hot?
Cables are managed -reasonably- well, considering the non-modular PSU, all fans are functional and quiet, and there's a strong draft of hot air out the exhaust fan on top. I'm just at a loss; this thing's a radiator at the moment and raises my room temperature 15-20 degrees F. I'm fairly certain it shouldn't do that at idle.
Any suggestions? I might be able to pull the CPU/GPUs and re-paste the northbridge heatsink, but as it's already hot I feel it's getting adequate conduction. I'm at a loss and would appreciate any thoughts you guys have.
Gigabyte 880GA-UD3H
2x Gigabyte HD6850
Antec HCG-750 750w
Antec 300 case
