RandallH1989
- Jan 28, 2004
When I started having lockup problems in games from overheating, I looked at my temps.. The computer is running really hot..
So, I open it up and my chipset fan is dead. Figuring that is the problem, I take it off and ghetto rig and 80mm fan over it. Only problem is, i can't turn the 80mm fan around so that it will exfiltrate air. It will only pump air in. Thinking I need more fans, I buy a big desktop fan and now I have that hanging over my computer.
I am using a program called SpeedFan to monitor my temps now. It has different temperature gagues, only problem is, I can't figure out which one is which.
It has:
Temp1
Temp2
Temp3
Temp1 (again)
Temp 1 is running at around 40c
Temp 2 is running at around 42c
Temp 3 is the one I am having the most problem with, as it will run around 46c until I start up a game, at which time it jumps up to around 51c and the computer locks up.
The other temp1 is running at around 45c
What could possibly be the problem here? How can I find out what Temp3 is?
Any help would be greatly appreciated.
The motherboard is an msi k7n2 delta. The computer has been running fine for over 2 years.
It has:
Temp1
Temp2
Temp3
Temp1 (again)
