JustinSane
- Jun 29, 2005
I was hearing a weird noise coming from inside my case. Sounded like a coffee grinder. I looked at my chipset fan and it was spinning weird. I just checked the temps in the BIOS and my chipset fan went from 7,000 RPMs to 500 RPM with a temp of 52 degrees. Thats a bad fan no lol?
EDIT: It was stopped spinning completely. Does anyone use this chipset fan with a DFI http://www.newegg.com/Product/Product.aspx?Item=N82E16835118014
Or if I get the same kinda fan that is already on there do you think it will save me the trouble of having to take the whole mobo out to install it?
