Chipset fan broke! Cause for concern?
sheady
After trying too hard to install my 2nd video card into my MSI K8N Neo 4 Platinum SLI, I came to realize that I had bent my chipset fan pretty bad. I've since disconnected it and have a large box fan keeping the air flow up.
http://www.pcstats.com/articleimages/200502/msik8nneo4SLI_det.jpg
Two questions:
1) Should I be worried?
2) What would be a good fan/heatsink that has a low clearance for long SLI cards?
Thanks so much for the help!
Get a new one, contact msi to send you a new one, or order a solid copper one, ect ect ect.
Man I remember those little things. So glad the current mobos went with heatpipes.
Try to epoxy a chipset heatsink on it with either fins or put a fan on it. Those tiny fans don't move much air. I can imagine a larger passive heatsink should be okay especially if you have decent airflow in your case.
I think you should get a new one, I replaced my chipset cooler with one from thermalright (with a bigger fan) because the little fans annoy me. Even with the much improved cooler the chipset runs hotter than my x2 cpu.
