Chipset cooler for Asus K8N-E?
Copyright
Can someone recommend a good chipset cooler for this board? Id like to run the tower model that thermalright has but not sure if it will fit.
What video card will you be using? You have to make sure the video card won't interfere with the heatsink. Try looking at this cooler. Looking at my K8N-E, it looks like there will be problems with a dual-slot cooler.
You can bend them as Asian said or you could cut them with a Dremel or another type of saw.
Why do you want to replace it? That all-passive unit that comes on the board is pretty nice.
