ChillZilla micro
BitchBreaker
Mixture is still to thick but i can sit at -20*c idle on my liqued temp's once the flow rate is back up!
Ill be building a "big brother" to this unit verry soon,1hp copeland compressor gassed with r-507 on a brazed plate HX :)
One warning for plathx.... If you do plan to put liquid through it make sure it is something that just doesn't freeze up inside. If it gets too thick, flow rate do drop drastically. And plate HX do remove heat incredibly well for that use.
yes i know Jin, thank's for the imput, i have a mix that me and chilly1 devised that was slush free and water like all the way down to -96*c :)
