I came up with this idea for hiding your PSU and Optical drive cables. It looks great too!
It only requires a sheet of acrylic cut the dimensions I've mocked up
(I'm afraid plexiglass won't flex as easy as acrylic and it will crack trying to install it)
You can try this mod on other manufacturer's cases, but the beauty of the chieftec Dragon full tower is that you don't need any fasteners.
I decided to have the HD 100th logo laser etched, but you could etch your design with A Dremel or use window etch style stickers, paint your sheet of acrylic, use clear or solid color!
Window for Chieftec Chassis
Download Video of Window Installation
Prepared image file for Laser Etching
Laser Etched .100 thick translucent Amber Acrylic
