Cherry picking a 5960X
Status
Not open for further replies.
Haha. Fair enough.
Can you give me this then?
What is your OC methodology? I've been modifying vCore and VCCIN...starting with 4.5GHz, 1.3v, 1.95v and working back (using 1 hour of ROG RealBench as a success criteria). I worked all the way back to 3.7GHz and still could not pass. I'm thinking I am not giving enough juice to something or else I have an EXTREME dog. Temps are great - Corsair H110 AIO; Gelid GC Extreme. Board is MSI X99S XPOWER AC and PSU is Seasonic X-1250 (memory: 16GB Corsair 3000MHz).
My methodology is to go straight to high voltages first, set a clock, and then dial voltages back down until that clock speed isn't stable or temperatures are out of control. For my testing I was running P95 small FFTs since thats as brutal as it can get for these things. I also set all the VRM settings to as extreme / aggressive as the BIOS allows (switching frequency, current limit, etc)
You should be able to crack 4 Ghz with a 5960X. Especially if your temperatures are good. http://www.tweaktown.com/guides/675...-spec-qfra-cpu-overclocking-guide/index3.html
Set VCCIN to 2.0V, Core voltage to 1.35V, CPU Cache to 1.25V, make sure the CPU cache multiplier is 30 (to eliminate that as a potential trouble spot), and increase the tjmax to 100C at least for now.
Status
