Just got my case today.
I've gotta say it's a damn nice case. Took some pics of it.
Yes, it's a Pre-Mod so no comments from the peanut gallery.
*Edit* I don't know what's with the black bars at the bottoms of all the pictures. I'm trying to get that rectified. It's coming from the place I host them cause they look fine on my computer.*Edit*
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0001_001.jpg
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0002.sized.jpg
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0003_002.sized.jpg
Yeah, it's getting some fans on this window.
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0004_001.sized.jpg
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0005_002.sized.jpg
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0006_001.sized.jpg
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0010_001.sized.jpg
120mm fans it came with. One in the front and one in the rear. Anybody know if these are decent fans?
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0011_001.sized.jpg
Yeah, see that? That's the 80mm blow hole fan.....it's coming out. Completely, gonna put a 120mm in it's place. Possibly 2 if I can fit them. Gonna measure and see how much room I have after I install the PSU. Hopefully I can get the drill in there to drill out the rivets, otherwise I'll Dremel them out.
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0012.sized.jpg
http://www.myneonspeed.com/arcade/modules/gallery/albums/GIR/PICT0013_001.sized.jpg
I dunno, I just thought that was neat. I can remove the entire back of the case and the mounting plate comes with it. I also like the plate that you mount the PSU to. It's nice not having to take the sides off to do anything.
There is also room enough behind the mounting plate to hide wires, another thing I like; better wire management.
This weekend come the transplant of my old case into this new one.
Edit - Crisp images 500 pixels wide are a lot more efficient to tell a message than gigantic blurry versions. Also a lot quicker to load. // mashie
