Check out this new possible system of mine, all prices are quoted from newegg. Tell me if you think I can get a better case that's Aluminum for not too much more money, and tell me what you think of the mobo and graphics card, and I need to know if that hard drive is going to work with it:
ASPIRE ATX Mid-Tower Case with 350W Power Supply (Yellow), Model "ATXB5KLW-YL/350" -RETAIL
Specifications:
Form Factor: Standard ATX
Drive Bays: External 4 x 5.25" - 2 x 3.5" Internal 4 x 3.5"
Expansion Slots: 7
USB/IO: 2x USB 2.0 Ports on Front Panel (see pics)
Case Fans: Side Panel UV LED Blue Fan and Top Panel UV Blue Fan with Matching Color Custom-Made Fan Grill
Power Supply: 350W Power Supply for P4/P3/AMD
4 Blue LED Lights on Front Panel and Blue Tint Front Acrylic Panel and Auto Paint Job on Case Body for Sleek Looking more info-> N82E16811144044 $40.00 $40.00
ABIT nForce2 Ultra 400 Chipset Motherboard for AMD Socket A CPU, Model "AN7" -RETAIL
Specifications:
Supported CPU: Socket A AMD Athlon/Athlon XP/Duron Processors
Chipset: NVIDIA nForce2 Ultra 400 + MCP-T
FSB: 266/333/400MHz
RAM: 3x DIMM support 3 Un-buffered DDR333/266, 2 Un-buffered DDR400
IDE: 2x UltraDMA 66/100/133 up to 4 Devices
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2xPS2,1xLPT,1xCOM,8xUSB2.0(Rear 4),1xLAN,3xIEEE1394(Rear 1),SPDIF In/Out,Audio Ports
Onboard Audio: 6-Channel AC97 CODEC
Onboard LAN: Realtek 10/100Mbps Fast Ethernet
Onboard SATA/RAID: 2x Serial ATA 150, RAID 0/1
Onboard 1394: 3x IEEE1394 ports up to 400MB/s data transfer rate
Form Factor:ATX more info-> N82E16813127167 $103.99 $103.99
ATI RADEON 9600XT Video Card, 128MB DDR, 128-bit, DVI/TV-Out, 8X AGP -RETAIL
Specifications:
Chipset/Core Speed: RADEON 9600XT/500MHz
Memory/Effective Speed: 128MB DDR/600MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: Driver CD, Manual
Max Resolution@32bit Color: 2048X1536@85Hz
Retail box(See pictures for details) more info-> N82E16814102331 $189.00 $189.00
AMD Athlon XP 2500+ "Barton", 333 FSB, 512K Cache Processor - Retail
Specification
Model: AMD Athlon XP 2500+
Core: Barton
Operating Frequency: 1.83GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info-> N82E16819103379 $90.00 $90.00
Corsair Value Select 184 Pin 512MB DDR PC-2700
Specification
Manufacturer: Corsair
Speed: DDR333(PC2700)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5
Support Voltage: 2.5V
Bandwidth: 2.7GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime more info-> N82E16820145407 $75.00 $75.00
Western Digital Raptor 36.7GB 10,000RPM SATA Hard Drive, Model WD360GD, OEM Drive Only
Specifications:
Capacity: 36.7GB
Average Seek Time: 5.2ms
Buffer: 8MB
Rotational Speed: 10000 RPM
Interface: Serial ATA
Features: Not specified
Manufacturer Warranty: 5 years
Remark: OEM Drive Only more info-> N82E16822144200 $121.50 $121.50
Subtotal » $619.49
Specifications:
Expansion Slots: 7
Specifications:
FSB: 266/333/400MHz
Specifications:
Specification
Core: Barton
FSB: 333MHz
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Specification
Cas Latency: 2.5
Bandwidth: 2.7GB/s
Specifications:
Capacity: 36.7GB
Buffer: 8MB
Subtotal » $619.49
