Is there any way to log the temp while you were gaming. for example, say i was playing a game and it takes long time to exit the game and start up the temp checking software (in my case rivatuner nad speedfan). Can i use any software to have it save the temp graph or log it so i can later check where my temp for everything were. I'm recently (hot room cus of summer) seeing BSOD and after it restarts i chek the bios and cpu temp is like at ~50C and i'm a little worried cus it might have been higher before. and the chipset temp rises to ~55. I recently oc'd my computer.
AMD Athlon 64 X2 3800+ @ 2.4 w/ stock cooler and thermal grease
DFI Lanparty ut ultra-d NF4
APEVIA X-CRUISER-BK Black Steel ATX Mid Tower
2 Front Intake, 1 Side intake, one top out and 1 rear out. one psu out.
Case temp hovers around 10-15c higher than room temp and soon the room temp will be like 30
