Check out what I just ordered :D
J-M-E
Name Code Qty Each Options
NEW!!! Aqua Computer aq-215xx 1 109.95 Fittings = pc-s
Cuplex XT CPU Block w/ Socket = Athlon64
P&C Fittings
NEW!!! Aqua Computer aq-23361 1 104.95 Fittings = pc-b
Aquagra FX 6800 R.2 VGA
Water Block GPU + RAM w/
P&C Fittings
NEW!!! Aqua Computer aq-31031 1 94.95 Fittings = pc-b
Airplex Evo 360 Heat
Exchanger w/ Fittings -
Triple 120mm Radiator
NEW!!! Aqua Computer aq-340xx 1 64.95 Color = Black
Aquatube Water Reservoir Fittings = pc-b
w/ P&C Fittings
NEW!!! Aqua Computer aq-34903 1 12.95
Aquajet Inlet Water Spray
Nozzle for Aquatube
NEW!!! Aqua Computer AC aq-53101 1 8.95
Fluid Non Corrosive Water
Additive
NEW!!! Aqua Computer aq-34902 1 34.95
Aquabay for Aquatube &
Aquastream
NEW!!! Aqua Computer aq-41043 1 114.95 Fittings = pc-sb
Aquastream Modified Eheim
1046 - 12V Centrifugal
Water Pump w/ Fittings
NEW!!! Aqua Computer Plug ap-90002 4 2.95
& Cool Straight Fitting -
6x1mm w/ 1/8" BSP Thread
NEW!!! Aqua Compuer Plug aq-90004 5 3.95
& Cool Bent Fitting -
NEW!!! Aqua Computer Plug aq-90003 4 2.95
6x1mm w/ 1/4" BSP Thread
NEW!!! Aqua Computer Plug aq-90006 5 3.95
6x1mm w/ 1/4" BSP
NEW!!! Aqua Computer aq-93097 1 16.95
Aquabay Mounting
Faceplate - Black
NEW!!! Aqua Computer Plug aq-61003 4 2.95
& Cool Tubing - Clear
NEW!!! Aqua Computer aq-32031 1 33.95
Airplex Radiator Mounting
Plate - 360
Subtotal 672.40
Shipping 28.29
Tax 0.00
Total 700.69
:D :D
+ I got some green UV Dye and faceplates from SNT systems
And a lot less fun!
Did you order from SNT or Sharka?
I hope from sharka for your sake and money.
WOW...i cant believe you spent $700 on a water cooling setup, have fun though :D
I got it from sharka.
I got some green uv dye from snt because they dident have it at sharka :p
Yeah the green UV dye is coming in on the shipment next week. What faceplates did SNT have that Sharka didn't?
the aquastreams error decting thing faceplate in black.
Hmmm. Which 120mm fans to use..
R1ckCa1n said:
I thought I saw the black faceplates on Sharka's shelves last week.....
I think they are too! I gotta keep on Wes to keep putting all that stuff he has in stock up on the website. :eek: I keep telling him it ain't gonna sell unless he puts it up on the site :rolleyes:
Hmmm, could I add another pump without having to add another rad and resivoir?
ROFL Do you want to know how much I have in mine?
Yes you can but you will need this A-C fitting which just so happens to be coming in on the shipment next week :D This will allow you to run two loops with your current system. You just need to have one going to the Aquatube and one coming off the Aquatube. ShoNuff uses that same fitting for a similar situation.
