Check out my OC
Before:
After:
VGA comparison - Default/OC:
-I would've gone farther on the cpu if it weren't for my crap Ram. It's two sticks of PC2700, they're not even the same brands, and they're crap brands at that.
thats a pretty good overclock, im being held back from 2.4 ghz with my 2800+ because of my crappy ddr400 ram. its soo bad when you cant do anything at all to increase your overclock. i think we both need to upgrade to some non-value ddr 400. also what kinda motherboard do you have?? cause im rocking the abit KV8-PRO which seems to be a good overclocker for me.
ps: are you at stock voltages??
Thanks. I got an MSI K8N Neo with Stock Voltages.
-and yes, we both need good RAM.
Also, I had to lower my VGA to 305/515 for stable game performance. I just did CS:S Stresstest and at default I had 59.1FPS and look at the results:
-Thats at:
800X600
Model Detail:High
Texture Detail:High
Shadow Detail:High
AA:2X
2x Anisotrophic
Shader Detail:High
I don't understand why you can't keep going on the overclock. Your memory is what it is but thats what the memory divider is for. (your still under stock on mem anyway) If its the timings you're worried about I think you'll be much happier with 100-200 more mhz.
I don't really know much more than how to up the fsb. How would I go abouyt changing the divider?
