check my spec (plz)
Chris_B
Trying to tame the beast that is my b3 quad, want to try and get a bit more than 3.2 out of it plus have a quieter cooling solution. Spec as follows:
Laing DDC 18w Pump (rev 3.2)
D-Tek FuZion Accelerator Nozzle Kit
3/8" High Flex Hose
D-TEK FuZion CPU Block
Thermochill PA120.2
Swiftech MCRES Micro Reservoir
Not sure about fans yet, 2x sflex 1600 or 1200 possibly.
Looks good to me, though you could get slightly better temps with petra's top and 7/16 or 1/2 inch tubing.
Was thinking about wider tubing but most online stores for a lot of the components seem to always have 3/8 as the main option, some parts do and don't have larger options, the resevoir for one (site depending).
Hmm actually that place does list it with 1/2 inch barbs. Might just go to 1/2 inch then.
