Check My First Mod
OMG!!!
there are so many colors, and i dont really see any "mods"
just every piece of different colored stuff that you can find tossed into a pre modded case.
maybe it would be helpful if you posted a list of mods that you did in case i am missing something.
also, get a new cd drive or paint that one or stealth it or something, because it just looks plain FUGLY.
on another thought.... WHY THE HECK DO YOU NEED A 560 WATT POWER SUPPLY??? :confused:
:confused: :confused:
see that uber blue led fan there???? that took SKILLS to mount bro! and his zip tying skills are just super [H]ard ;)
any ways, besides the fact i highly dislike cases with alot of lites adn stuff, ill ask you a question...what's that video card? heatsink on the back?!?!?!
lol.
Uh, When I purchase parts I tend to spend a few more bucks to go "overboard" - Thats where the 560w came from.
The only "Modification" to the case was me dremeling the top rim of the front door so I could make use of the top 5.25" drive bay, It wouldnt close with this rim intact. Also, with the dremel I etched my intitals inside the front door.... Which is quite LEET!!!1!111!!@111!! :eek:
Basically I used this build to get some wire managment under my belt... The PSU came modded, but I sleeved all the fan cables and some of the case wires. I like cable ties. =D. This is my second build and first "mod" (On the first build I purchased a case and just threw the shit in, on this build I took time for wire mgmt.) I'm happy with it, and I learned alot by doing it. I'm going to attempt OC'ing soon, after I read up a bit.
The red fan cable sleeving is from xOxide.com, and It was on teh site as "Red UV". As you can see it is not UV reactive, I just want to point this out so noone makes the same mistake as me.
even though he did ask for you opinions you could atleast show some courtesy..
Nvidia Geforce FX 5700 Ultra.
