Is there a program I can use to check a hard drive for errors? I think the drive is starting to go bad, so I dont want to use it if it has any serious errors. Thank you.
Look at the SMART data for the drive with a program like CrystalDiskInfo. This information is statistics that the drive keeps on how many problems it has had since it was first used.
Where can I get this WDDLG program? I searched for it but I havent found a site for it.
If the drive passed HD Tune's Error Check, should I consider it to be working 100%? Sometimes the drive makes a strange noise, that is why I am a little concerned.
Also, I checked the SMART data for the drive, but I am a little confused about how to understand it. There are 5 columns titled, Current, Worst, Threshold, Data, and Status. And then there are like 20 different rows under these columns such as 'Raw Read Error Rate', 'Reallocated Sector Count'. What am I looking for to determine the drives health?
Reallocated_Sector_Ct can be non zero but you do not want to see this growing on a daily bases.
Current_Pending_Sector and Offline_Uncorrectable you want to see these being 0 because they tell you the drive has bad sectors that were written to and it can not read the contents. I have sometimes seen non zero numbers for these two on drives that were quick formatted and after a full format these go back to zero.
UDMA_CRC_Error_Count tells you about interface problems. Sometimes you will see a small number here but if you have 1000s here there is either a cable problem, a SATA card problem or the hard drive interface card is bad.
