Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Could just hook it up to a powers source of another machine and let it run I suppose. If you have no other machine to test you could install your parts with the stock cooler/temporary cooler if you have one and run the AIO outside the case powered by the PSU.
The cooler should be filled with non-conductive liquid. Even in the event of a leak, it should not destroy the parts. You just have to deal with the messy liquid/oil.
the leaks are rare but they do happen, and i really doubt those coolers have nonconductive liquid in them, all you need to test it is turn on the pump, so connect it to another running computer or a 12v battery and let it run for 15-20 min
I was a little paranoid with my H60 when I first got it about a month ago about leaking, constantly looking..But now that is over and I couldn't be happier with the performance..Much cooler now than my old Cooler Master V8..
I would imagine the liquid would already be leaked everywhere when you got it, but if you really need to... I wouldn't do this, and would honestly just trust that it works (haven't had issues the couple I got, just had one die after years of use): Get a tub of water, submerge it, wait a minute and see if bubbles rise up. If they don't you are good to go!
